2016 Beta 350 rr Sachs forks stacks (open chamber)
2016 Beta 350 rr o/c
Forks std
12mm rod
12mm Spring preload
Oil level 125mm
Comp
18x0.1
25x0.1 (2)
16x0.1
22
25         (2)
23
22
20
18
16x0.15
14x0.15
12x0.15
10x0.15
Mid valve
20x0.1 (2)
19x0.1
17x0.1
11x0.2
11x0.2
11x0.2
11x0.35
Float 0.35 feeler gauge measured
Rebound
3xDelta 0.1mm
16x0.1
12x0.1
16x0.1
10x0.3
Am told the insides are a copy of the WP forks but am unsure as I'm not familiar with either. Other notables the base valve threads are much finer than jap stuff, no peens (YAY). These stacks are way different to what was in the 2015 390 posted in here a few months ago.The delta shims on the rebound face were different to one another, the two on the face were pointier than the 3rd one. Sachs have been proactive for sure. Hope this helps someone.
Cheers
Marty
ps base valve still 7mm ID :(
Edited by MartyMOOSE
Ahh yes I tried a 0.4mm each side of the face shim it would not fit. I'm going to play with them will post up another thread later would appreciate your input in you feel inclined :)
Thanks. Strange com. Stack for sure. You going to change? Wonder what rate the spring is?
Yes bleed everywhere
The only bleed I can see is in the base Mog the 18 on the face! Do you mean the cross overs ?
The springs are 0.48 E-TECH
MM
