Please help JD jet 2012 CRF250x
The bike has an FMF header, exhaust, and the air box has been cut w/4x4 opening.  I'm also going to remove the emissions.
Riding area will be from 1-3000' and the temps are in the 50's.  I'd like to install something that wouldn't require me taking the carb off for winter/summer temp changes.....is there a set up for that?
What would you recommend to install with my JD jetting kit?
Thanks for any input!
45p
R&D fuels screw to adjust the pilot correctly
NCVS or JD red needle on the 4th clip
55 leak jet
165 main jet
all other jets no change
Learning the proper way to adjust your fuel screw will yeild you the best riding experiences
