Bad rim?
Recently bought an 05 yz125. The first week I had it the rear tire kept losing air and the bead would fall inside the rim. I went and put a new tire on it thinking that it would fix the problem. Well after 3 hours of riding today I get the bike home and see the same thing. This tire is also losing air but I didnt think anything of it before now. The rim "looks" straight by the naked eye but I think it might be bent. Anyone else run into something like this? It is the stock rim on the bike. Maybe I should think about upgrading to aftermarket rims and hubs.
I would change the inner tube and rimlock sounds like the rimlock got tore up and popped the inner tube. Happened to me a few times.
Edited by Matt Gunter
It's the inner tube that holds the air, not the tire or rim.  (unlike a tubeless tire on a car)
You could run a bald tire mounted on a bent rim and it wouldn't matter as long as the inner tube held it's pressure.
A new inner tube, a new rim strip (or 1-2 layers of duct tape will also work)
and inspect inside the rim/rimlock if anything sharp is rubbing on the innertube.
Edited by mlatour
