Conversion -single rad to twin
92-01 engines were the same, the new tank would be needed as the plastics mounting points are likely different, there was changes to the rear linkage also so not sure if you would need just a linkage or the shock also.
if you could find a blown up 00-01 for cheap it would be pretty easy.
