bde0001 Posted November 22, 2015 I want to order sprockets for my ssr125 but how do i kno what kind to get. I'm looking to give it a better top speed. Share this post Link to post Share on other sites
KRAYNIAL My Rides (5) Posted November 22, 2015 I want to order sprockets for my ssr125 but how do i kno what kind to get. I'm looking to give it a better top speed. Do you mean you want to reach a higher top speed in the highest gear? Are you running out of speed (motor reving too easiy) or are you running out of motor ( doesn't go fast enough) ? Your bike is not very high powered, so if you 'gear it up' you will slow the bike down, and create 'power gaps' between each gear when you shift. Try going to a countershaft sprocket that is one tooth bigger. Make sure your chain is long enough for it to fit (room to slide the rear wheel forward) Your Share this post Link to post Share on other sites
justaskmenicley My Ride Posted November 22, 2015 The correct ones are the ones that fit your bike. Share this post Link to post Share on other sites
T Bolt USA Posted December 5, 2015 Take a quick measurement See TECH http://tboltusa.com/store/tech.php?pID=168/Front+Sprockets+or+Countershaft+sprockets All 50-110All 140-190 Pitbike engines take 14/17mm type 125cc can be either 14/17mm or 17/20mm shaft type Share this post Link to post Share on other sites
