Anyone have the Rekluse manual clutch?
I was about to buy the full Hinson kit with basket, inner hub, pressure plate, fibers, steels, springs and clutch cover but I see Rekluse sells two different versions of the manual clutch for the yz. Anyone have a review on either one? Lighter clutch pull then stock? My basket is notched so looking to upgrade my clutch soon.
The Rekluse unit uses 9 thinner plates vs the stock 8 plates. More contact area, consistent clutch engagement, less chance of fading, better clamping force... In theory a more revised clutch system. You will have to use Rekluse clutch plates with the Rekluse system.
Hinson is excellent and built a name but Rekluse is equally as good.
the rekluse torque drive manual clutch looks tobe a cut above hinson. Although hinson has proven itself in the hands of thousands of pros bikes for years.
