Help please. 2008 kx 450f swing arm comparability
been searching this with no definitive answer. Was hoping someone crossed this bridge. Will an 06 kx 450 swing arm fit my 08? My chain tensioners seized. The buddy kit is $40 plus the time to install. A 06 swing arm from eBay is $100. I'd rather just buy the swing arm an put it on. Thanks for your help.
Edited by Dustybottomz
Thank you. Part numbers are different on kawi' oem site. Bike bandit lists the same part number for both years. I've read the frame was widened from 06-08, hence the hesitance. So far, the best answer I can produce is a definitely maybe. Thanks for the reply. I'm not very kx savy yet.
Sometimes they change part numbers just because the year changed,I know the linkage will bolt up so the arm should be the same.
