Wheel wobble?
My front tire has a slight wobble whenever you spin it which also makes the brake disk have some kind of high spot for just a second in each revolution. I'm pretty sure it's because the tires not "true" some spokes are loose and some are more tight. So how do I go to fixing this with out taking it into a shop?
Time , spoke wrench , dial indicator
You loosen all the spokes then go around and slowly tighten all of them and try to to keep the wheel true
They'res plenty videos on it go on you tube and search how to adjust spokes dirtbike or something .
Don't try to short cut this or you'll break some spokes and potentially lose the wheel causing you to crash .
