x2fanatic Posted November 22, 2015 I have changes my oil a bunch of times and I have never pulled the oil level screw out, I always just put the amount the manual says (about 27 oz). This time I pulled the screen out while I filled it and oil came out at about 20 oz. Should I just keep putting the recommended amount or should I stop when the oil comes out? 1 Share this post Link to post Share on other sites
KTMRider4Life Posted November 22, 2015 Most people do not remove the check bolt and just fill with the reccomended amount. I'd even venture a guess that most pull in a full quart in the bikes that suggest .7 or.8 liters under the impression that a little extra is good, I'm not one of those people. I fill my bike with the reccomended amount .7liters on a 200. 1 Share this post Link to post Share on other sites
M A T R Posted November 23, 2015 Most people do not remove the check bolt and just fill with the reccomended amount. I'd even venture a guess that most pull in a full quart in the bikes that suggest .7 or.8 liters under the impression that a little extra is good, I'm not one of those people. I fill my bike with the reccomended amount .7liters on a 200.why do most people not pull the check bolt? Share this post Link to post Share on other sites
KTMRider4Life Posted November 23, 2015 why do most people not pull the check bolt? Two reasons really I "believe" most people dont pull it. 1. They know they over filled it and oil will come out, making a mess. 2. They're afraid they'll strip it putting it back in. I don't pull it becase I measure the oil before I put it in and I know there's enough oil in there. 5 Share this post Link to post Share on other sites
highmarker Posted November 23, 2015 With the oil fill on the same side as the check bolt you'll have oil coming out it before all the oil gets to the other side. If you let the bike sit level for awhile you'll find it needs more oil than what the bolt level initially showed. Closer to the specified amount. 1 Share this post Link to post Share on other sites
KTMRider4Life Posted November 23, 2015 With the oil fill on the same side as the check bolt you'll have oil coming out it before all the oil gets to the other side. If you let the bike sit level for awhile you'll find it needs more oil than what the bolt level initially showed. Closer to the specified amount.So do you pull and check the level or pour in specified amount? Share this post Link to post Share on other sites
x2fanatic Posted November 23, 2015 I put 1 oz less then the recommended amount. Seems to be fine now Share this post Link to post Share on other sites
7Tktm Posted November 23, 2015 The level bolt is the easiest one to strip on a KTM. You can do it without trying. Share this post Link to post Share on other sites
x2fanatic Posted November 23, 2015 Yeah I was very worried about stripping it. I stripped the one on my crf. At this point I'm going to put a little less so it's not over full. From what I hear the 2 strokes are not as critical about the oil like a 4 stroke Share this post Link to post Share on other sites
highmarker Posted November 24, 2015 So do you pull and check the level or pour in specified amount? Done both depending on mood. The ktm level bolt isn't near as fragile as the crf. Share this post Link to post Share on other sites
orangyktmthing Posted November 24, 2015 I always toss my 300 on the stand and pull the check bolt when filling up the trans oil. They just have to be snug, using he-man strength causes the threads to get beat/stretched and then to strip. Steel bolt....aluminum inner cover.... 1 Share this post Link to post Share on other sites
The Deplorable Posted November 25, 2015 The 250/300 takes 800cc's. I just drain and refill. A plastic measuring cup from the grocery store is cheap. Share this post Link to post Share on other sites
HondaH8r904 Posted November 25, 2015 As long as the engine is warmed up and you give it enough time to drain, i see no problem with putting in the factory recommended amount and not messing with the overflow bolt. Even though i still do it that way Share this post Link to post Share on other sites
hawaii500_1999 Posted November 25, 2015 I stripped mine. And yes, I you fill til it comes out. Then let it sit for a while and come back. It will need more. Especially with the thicker oils. Not so much with atf. When I stripped mine, I pulled the cover and took it my shop and machine it out and converted it to a sight glass. I like sight glasses better. 2 Share this post Link to post Share on other sites
M A T R Posted November 25, 2015 I stripped mine. And yes, I you fill til it comes out. Then let it sit for a while and come back. It will need more. Especially with the thicker oils. Not so much with atf. When I stripped mine, I pulled the cover and took it my shop and machine it out and converted it to a sight glass. I like sight glasses better. i want to see a pick of the sight glass please 1 Share this post Link to post Share on other sites
Swappa My Rides (6) Posted November 25, 2015 I stripped mine. When I stripped mine, I pulled the cover and took it my shop and machine it out and converted it to a sight glass. I like sight glasses better. Bit of a thread jack, but I have the same problem. Can you post a picture? I like the idea of a site glass as an option with the countershaft seal that never seems to quite dripping and 20hr recommended oil change interval. What part number did you use for the site glass? Share this post Link to post Share on other sites
hawaii500_1999 Posted November 25, 2015 (edited) i don't have a close up of it. but i have this picture. it is covered in a thin coat of mud. i'll see if i can crop the pic in a little bit. Edited November 25, 2015 by hawaii500_1999 Share this post Link to post Share on other sites
hawaii500_1999 Posted November 25, 2015 if i remember I'll snap a pic again tonight for you guys. it is covered in mud now too though. LOL i rode a lot on the weekend. didn't clean it yet. here is the previous one that is cropped. Share this post Link to post Share on other sites
hawaii500_1999 Posted November 25, 2015 oh. here. found a better pic on my work comp. this is before a ride pic. so no mud yet. 2 Share this post Link to post Share on other sites
