13 rmz250 lighting coil?
Where can I find a lighting coil for a 2013 rmz250. Planning on doing a 24 hour race and need to get lights on my bike. Anyone got a link. Or is the stock stator powerful enough to run a decent headlight?
You can find it on the right side under the tank. It´s for powering the controlunit. two wires. Max 30watt and you may have to give some gas when you start the light. Didn´t work with 35w xenon, I´ve tried. Better with LED-cree convert to 8.4v and use bike-light with batterie as backup.
http://www.ebay.com/itm/5000Lm-2x-CREE-XM-L-U2-LED-Front-Headlamp-Bicycle-Bike-Light-Torch-Headlight-/272061371988?hash=item3f581f1654:g:OpMAAOSwZVhWSZ9H
http://www.ebay.com/itm/111630885311?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Good luck
MX-Wall,
Do you have more details you could provide? Pictures or anything.
Reason I ask is that I also have a 2013 RMZ250 and found this on the Baja Designs Website. http://www.bajadesigns.com/ProductDetail?ItemNumber=129044
when I called they said the 2013RMZ250 does not have enough power to power anything and the bike would have issues.
So the right side under the tank, do you think this is where that Baja Designs wiring harness splices into? It looks so nice having a pre-built wiring hardness but they are telling me it wont work.
Amazing, thank you very much, this is exactly what I was looking for and couldn't find it any place with google.
Thank you again.
