2015 ktm 500 exc turn signals not working
so I bought the led signals for the back and the flasher that plugs right in. But nothing happened the front doesn't even work. Everything worked fine with the stock stuff on there
Did you try without the after market flasher? If you are only doing rear signals you don't need to change the flasher. They will blink a little quicker that's all.
I'd plug the stock ones back in and start over paying attention to each step.... Before that though id check the fuse under the seat first just to be sure the new stuff didn't blow a fuse.
