Shavings in transmission
So I picked up a old 1986 kx 125. It didn't have plug it in when I got it. (Got it for super cheap) stopped on the way home and got a plug for it. Cranked it up and when I pulled in the clutch and shifted down it just stalled tried it again and again still it just lurched forward and stalled if I didn't give it any gas. So I took the clutch apart and found that all the clutch fibers and steels were stuck togeather. I cleaned them up and put it back togeather. Cranked it up pulled the clutch in and shifted to 1. It worked normally, just a lot of top end slip. Also when I shifted I had to tap the shifter back down then pull up on it to go from like 2 to 3. I decided to change the trans oil and there was a bunch of oil shavings that came out. So I tore it down and cant see any visible wear where the shavings could have come from. Any ideas? ImageUploadedByThumper Talk1448314023.260365.jpgImageUploadedByThumper Talk1448314036.175380.jpgImageUploadedByThumper Talk1448314067.840382.jpgImageUploadedByThumper Talk1448314183.320481.jpgImageUploadedByThumper Talk1448314212.937429.jpg[attachment=283730:ImageUploadedByThumper Talk1448314325.43
I would lightly sand the fibers and steels and try again with fresh atf for oil.
make sure the basket isn't notched
the metal you see is likely from the aluminum clutch plates, swap them to steel.
and as above check the basket for notching, a notched basket will do exactly what your bike is doing.
replace it with a wiseco, lifetime guarantee against notching.
