2000 YZ 80
I have a yz 80 and I just cleaned the carb. Is it normal to drip a few drops of gas when I turn the fuel on?
Where is it leaking from? If it is leaking from around the bowl then it needs a float bowl gasket. If it comes from the overflow then either your float height is off a little bit, or there is something stuck in the spot where the float needle seals, or the float needle is worn and leaks. an easy way to test is to take the carb off the bike, drain it and turn it upside down. If you can blow air through the fuel inlet with it upside down, then there is something stuck in it or it needs to be replaced. if not then It is float height adjustment.
Edited by M3NT4L5
