How to remove Oil Sight Glass
Just posting pics showing how to remove the oil sight glass. I wanted to remove it prior to powder coating. Googled it and some said you couldn't some said (Thumper Talk) you could but no pics.
Basically, you scrape out the sealant from the front and it will, reluctantly, push in. Make sure you place something to protect your fingers on the outside when pushing in and something for it to fall on.
While at it, if equipped, replace the crank end seal and relief valve o-ring. Both are held in by circlips.
No comments needed, just an FYI.
Edited by HRC27
