2004 XR 100R jetting question/ hard restart warm
Hi, my question is, all else being equal what is the difference in idle mixture/ CO reading between a # 35 pilot idle mix screw screwed out approx. 2 turns and a #38 screwed out 3/4 of a turn??
I can't  get my head around it, much of a muchness surely??   You are compensating for a richer jet by having to screw the mixture screw in further  giving a leaner mix. ( but same as with the leaner jet )
I am asking this as I am having hard warm restart problems having to half choke to restart
I may raise the needle one clip from stock and recheck/raise fuel level.  Ant ideas ??
Runs ok otherwise, has a 98 main jet.     Valve clearances set slightly looser  at 3 and 4 thou.
Regards from OZ.
