05 YFZ 450 wont start seems as if it has to much compression
I have a 2005 yfz 450. Motor is built has a light weight crank and pro circuit piston stage 2 hotcams. I do not know if it is a high compression piston though. But the problem is my wheeler wont start. It seems as if it has to much compression because it has a hard time kicking over and battery cannot turn it over either. Any ideas? Thanks.
If it was starting fine before, then your problem is not due to high compression but like justaskmenicely said, a bad battery, corroded terminals, or something along those line.
