jridd Posted November 24, 2015 Had my forks rebuilt not long ago and they began leaking from the rebound adjuster. I pulled the screw off and lost one of the bearings. Where can I find one of the missing bearings. Share this post Link to post Share on other sites
Betarocker My Ride Posted November 25, 2015 Take a caliper and measure the other bearing. Share this post Link to post Share on other sites
Burnrider Posted November 25, 2015 (edited) Look up the part on RMATV. The bearing is listed as a 3mm ball bearing for my bike. To disassemble - place a rag over the adjuster and catch the ball & spring. (For next time) You should clean the cap bore with some scotch guard and replace the 'O' ring to prevent leaks. Bel-ray, Motorex gel grease or Silicone grease are excellent lubes. Replacing it in your plastic RBD adjuster - grease the stem, place the spring with bearing on top. Use a 10mm open end wrench to twist slowly loading spring & bearing into stem. Place it on the cap and press down til bearing is in the cap. Remove endwrench. Edited November 25, 2015 by Burnrider Share this post Link to post Share on other sites
jridd Posted November 25, 2015 Thanks for the info, I had no idea where to look Share this post Link to post Share on other sites
