Belleville Clutch Spring Preload - X, Y, Z positions
Hey all, just looking to confirm some research I've done regarding the belleville clutch spring, and the different hole positions you can use on the retaining ring (to get a different amount of preload).
X position   ->   lighter clutch pull, but more likely to slip under load
Y position   ->   stock setting
Z position   ->   heavier clutch pull, but better engagement
Can anyone confirm that the above is correct? Or do I have the X & Z positions mixed up? I'm running my timbersled on my 300 xc-w this year, and want the strongest clutch engagement so there's no slippage under load.
Thanks.
Hello,
Your data is correct.
If you want you can use a 450 bellevile that is little stronger and makes the clutch more agressive.
