12 te 310 bring pain in the ×++# !
12 te 310 1635 miles on it , took it in for e start not working 300 miles ago , they replaced starter motor , temp sensor , said stator was working fine , valves all in spec , wouldn't e start today , kick starts fine , so now it's back at the dealer .
From what I understand the e start is very dependent on a good battery with high cranking amps. Using the e start when the battery is low can put a strain on the e start so do make sure your battery being charged properly and its also a good idea to let it recharge in-between starts during a ride. I use the kick whenever I have to restart after short ride. I also use a BatteryTender designed for lithium batteries to ensure my Shorai lithium it fully charged before each ride.
