2008 te450 wont stay running
I was riding the street , after 8 miles the bike died .
When I turn the key on , I can hear the fuel pump cycle , it will only start if I give it about 1/4 turn on the throttle
And no matter what I do , it dies about 3 seconds later .
The bike did sit for several months with stabil and super gas .
I did drain and fill it with new gas , also has a new battery , ( I tested it good also )
Any ideas where to start would be greatly appreciated.
2 questions ,
1 which relay is for the fuel pump once the bike is running ?
2 if fuel pump is suspect , what is the recommended one to use ?
Could be a vacuum lock. Take the gas cap off and see if it'll fix it. If it does, start looking at all your hoses.
