04/5 125 cylinder pics...
If anyone can post up a pic of the bore of a 04-05 cylinder on the intake side, I'd appreciate it.
I'm doing some research and trying to figure out why Wiseco makes a different piston for 03 vs 04/5. And a $10 difference. What I've come up with so far is:
The ring locating pin on an 03 is offset from the intake window and the ring split rides along a bridge in the cylinder. The 04/5 piston, the ring split is directly up the middle of the intake window and I want to see if the 04/5 cylinder has a different design and a bridge up the center of the intake side. If not, what's Wiseco thinking???
On another note, Vertex and Pro-x use the same p/n for 03-05. I have run Vertex before but don't have any in the old piston box. I do have about 25 wisecos though for my sons 03. But I am working on a kids frankenstein bike and it has an assortment of parts used on it.
Here's some pics to refer to.
03 piston
04/5 piston pin would be located here.
The porting is identical between them as far as I can tell without measuring.  The ring gap would pass over the center of the boost port in the later design.  This isn't necessarily a problem.  The port is too small to allow the ring to hang out and snag.
I ran an 05 cylinder on my 03 125 at one point to revert back to stock porting.
