02 RM250
use quality oil at the right ratio make sure your air filter is clean, use premium and above, clean the carb make sure its tuned, get a fuel filter, dont hold wide open throttle for long periods of time at high rpm
I use to own a '02 RM250, the first thing that I would do is replace the piston with a Wiseco forged ~ the '02 RM250 had a history of destroying pistons (mine included).  After that I would install a 9oz flywheel weight and if your a trail rider go ahead and buy a FMF Gnarly pipe and FMF Turbinecore silence.  And if you still have some coin to spare a steering damper would be nice too.
After that it's all normal dirt bike maintenance stuff.
Read this, you'll be glad you did:  http://www.eric-gorr.com/images/documents/SuzukiModelTuningTips.pdf
My '02 RM250
