Need some advice on a 04 Crf450
Just purchased an 04 crf450 and I am questioning the way the bike sounds and backfires? Is this normal for it to backfire and shoot flames out? When the choke is on it runs smoothly but when I take the choke off it backfires and whatnot on the deceleration of the throttle. Any advice would be great. Thanks
Not normal. Sounds like it is "lean popping". Cause by a lean pilot circuit. You need to confirm the pilot jet isnt blocked, then open the fuel screw 1/4 turn at a time and retest until the popping stops. Depending how many turns the fuel scew winds up at you may need to go up a size pilot jet.
