2001 KX250 front end.
Does anybody know what forks and triple clamps are compatible with this bike?
Or is it possible to put any 450 steering assembly onto this bike?
Any information would be awesome[emoji106]
Not sure. It starts getting more complicated. Kx250f might work. You'll need the wheel, fork, brake, fork protectors, triple clamps. Problem is the triple clamp stem is probably the wrong length. You may have to press your old stem in the new triple clamps. Then you have the triple clamp offset to deal with. Your KX has a 22mm offset. A lot of the kxf are more like 25-23mm offset. I think from about 2011 the kx250f went to 22.5mm.
There's also the length of the fork to consider. If it's too long or short, it'll throw off the whole bikes feeling.
In reality you're better off getting a 2002 triple clamp and fork, and getting them tuned good by a pro, or do the same with your 01 set up. It might be money better spent.
