2016 FE 350 brake light
I'm new to the forum but have been reading posts for a few years I have a 2016 FE 350 and want to put the brake light pressure switch on. On my other KTM bikes I had to replace the tail light assembly because there was no lights.  This bike has a tail light that for some stupid reason they made it to work as a running light.  Has any one else done this mod I want to avoid replacing tail light with the 350S unit. Any help or advice would be appreciated.
Thanks,
Bob
I picked up the Sicass racing rear brake switch installed it and it plugged into the wire harness without any splicing required.  It turned rear LED running light into a brake light.  What I was wondering is if any one has done this mod how did they route the wires.  I am trying to avoid the exhaust pipe while I avoid drilling or cutting the airbox/subframe. Any help would be appreciated please include photos if possible.
Thanks
I ran it inside the subframe then on the outside of the frame... works good so far
Sorry took a bit on the pic
Same as I did on our FE250.
