XR250R Blowing white smoke and oil drained quick
Just had my 2005 xr250 in for a service and roadworthy and have done just over 100km and while riding today i notice it started to blow a bit of white smoke. I got home after the ride today and turned if off for a hour then started it up and once it got warmed up the smoke started coming out again... also just checked the oil and i can just get a reading on the dip stick and i have only done just over 100km since oil change. So what is my solution here?
Not enough information to give a solution.  Try changing oil to 20W-50.  Next would be a leakdown test.  After that, disassembly, inspection, and precision measurement.
I had a xr400 do the same thing the oil rings had gotten weak replace all the rings no more smoke
Firstly, call the shop that did the work, it sounds like someone screwed up.
But from now on replace your oil & filter yourself for starters. I brought an 01 XR250 which just had a service by a workshop. It had over 5L of oil in it, about 2L fell out of the air box when I inspected the air filter.
The late model 250 requires around 1.4L.
