Floating piston depths
Does anyone know if there is a rule or formula for calculating IFP depths? If so is it based on volume, height of reservoir or both and does it apply to any shock wether it's remote reservoir or a mono tube design?
it should not hit the end stop on a extended shock, but should be close to it.
if it hits the end stop, the oil will not be pressurised then.
if it's to far from the end stop, the pressure rises too much at the end of the stroke
