Help front rim questions
So I have a 96 RM125 and I bent my excel rim. I ordered a 99 rm250 rim that said would fit but doesn't let axle go thru all the way. Question what years fit a 96 front rim.Everyone and there mother claims 96-00 fits but oemcycle.com and others say 96-00 same axle but different hub. But how does 01-08 have same hub as 96 but different axle. Help fellas.
The 99 RM250 wheel should bolt right on, unless it's not actually from a 99 RM250, or you have a different front end on your bike. The hubs have the same part numbers for both bikes.
Edited by shutupandride
What site did you use to see that? Oemcylce says like 145-fr 20mm while 97+ says 257-20mm for hub. However the rim I got looks like a possible RMZ per the look of rotor. But all these parts sites says 96 is different from 97-99. So much conflicting information I just can't keep buying the wrong stuff. But you type in 96 rm125 front Rim and everyone says it fits.
