Throttle cable replacement - XR400
One of my throttle cables needs to be replaced on my 2002 xr400 because the housing is worn through (stock carb/cables).  A couple questions:
  1. Is there any issue with replacing only the one, or is it good practice/maintenance to just do them both?
  2. Are OEM cables the best bet or are there aftermarket cables I should be looking at?
Thanks!
Going with stock is would be the easiest. https://www.rockymountainatvmc.com/oem-schematic/2
Motion pro makes good cables but you'd most likely have to have them custom made to the stock parts specs.(length, type cable ends, etc.) or try to find a ready made set that's close enough. http://www.motorcycle-superstore.com/10025/i/motion-pro-throttle-cable
