Chains breaking
What kind of chains is everyone running,my son rides 2014 kx450 and has broke 2 chains and 1 chain on his 2015 one was a stock chain 2 were rental r1.I alway run chain at the max for slack recommended thank you appreciate any input
i thought i read somewere that renthel had the most tensial strength. We run pro taper and renthel
I ran the renthals for a few years and on my 06 they stetch to fast and have a short life. I have been running the DID vx2 and they work awesome also heard good things about the DID Ert2 but never tried one.
Thanks for your responses ,our stock chain we got like 6hrs out of it before it broke the r1 was in between 10 and 15 hrs the first one went through cases was about $600 fix .i was wonder if renthal changed company's they were getting there chains from thanks again for your responseimage.jpg
What are you guys doing to break chains so much. I cant ever recall my son nor i ever breaking a chain on big bikes. Stock chain or after market. His kx85 yes,broke a few. You guys running them too tight. Not enough chain lube???
Edited by spin05
No never had a issue till last year,chain are always lubed and no not to tight , one of my thought were the chains maybe coming out of China
that wouldnt surprise me
Deleted post because i answered the wrong person
For you who started the post
Double Check your manual because you shouldn't brake so many chains
Edited by skorpan777
The specs on chain are right on ,I even go as far as to torque the axel nut.i just not sure if the power of the newer bikes is issue or as most products are now made inferior to what they use to be .believe me my sons been racing for 11 years now and he just turned expert ,his bikes are very well maintained.
It could be the qualit.
Trie DID chains i have good luck with them
So what protective parts can u buy to avoid the case eating chain problem? I have the sorta u shaped thin chain gaurd piece on up at the front sprocket, is there a better choice available that will stop the chain?
The case saver we had on we're the the chain put hole in cases was a hammer head ,and that got destroyed if I find it I'll post a pic of it. As of now we running t m design l guess it worked cause last chain didn't put hole in case. I am going to try the d.i.d chain
You've got something bad going on, for sure.  A 250 two stroke makes about the same amount of torque and they aren't breaking chains all over the place.  I've got two years on my DID o-ring chain and it is worn almost flat on one side.  I don't take it easy either.
