Trail Tech Fan Install
I'm installing a Trail Tech fan kit on my '07 X and noticed the mounting tabs on the radiator don't line up with the fan bracket. I tapped on them gently to get them aligned, so that issue is resolved. My question is should the fan rest flush against the radiator fins? Mine is sitting about an eighth inch away. And yes, I already trimmed an eighth inch off the top right mounting tab per the instructions. It appears that the metal tabs on the radiator are preventing it from sitting flush. I guess this is normal because if I bend the tabs outward to clear the fan, the holes will no longer line up. Is this normal or am I doing something wrong?
Radiator is good. The tabs prevent the fan from sitting flush against the radiator. I'm only talking about maybe an eighth of an inch. It's fine.
