Not sure where to start on fixing the forks
Ended up over shooting a jump and landed a bit hard and have my rim at an angle compared to the forks. The rim is fine but when I took off the rim and put the bolt through the to line up the forks, there's a very obvious angle (15 degrees) when the bars and forks are lined up straight. Is is possible that this is a simple fix or could it be that I have to get new forks? I'll try and get pictures up to help show the angle. Thanks for any help!
Reinstall the wheel.
Loosen the fork clamp inch bolts.
Hold the wheel between your legs and the bars in your arms.
Twist.
Confirm it is straight and gently tighten the pinch bolts.
  • Like 2
