Acerbis handguards
Ok, first bike, only moderately mechanical. I have put on the case guards, ground down the shift lever, installed a luggage rack and a Parabellum windscreen.
I tried to put on some aver is enduro/sm handguards but apparently have reached my level of incompetence. I assembled them but when I removed the handlebar end I think whatever the end piece screws into slid up into the grip.
I see how to attach the other end, but now I can't even get the original bar end back on.
The instructions are pitiful and I can't anything on you tube
Acerbis. It changed that when I posted.
Here's the fiche showing how it's assembled. http://www.partzilla.com/parts/search/Suzuki/Motorcycle/2006/DR-Z400S/HANDLEBAR/parts.html
It has been years since I removed mine but I think you just loosen the bolt a couple of turns and then give it a tap inwards to loosen the expansion nut and the whole works slides out together.
maybe try threading in just the bolt without the bar end so you can look in with a flashlight?
