Rmz 250 Excessive Blow By?
Hey guys I've had this 2004 Rmz for a while I recently rebuilt bottom, top, and valves everything is brand new bike starts and runs perfectly. I'm having trouble with it blowing oil out of the bent tube on a straightaway on my local track, also when the bike is started and then shut off after a few oil slowly leaks out after it is shut off, I always drain all the oil out and put the specified amount in just curious if anyone knows a fix, my rear brake pad budget needs to be cut. Thanks.
"I'm having trouble with it blowing oil out of the bent tube on a straightaway on my local track, also when the bike is started and then shut off after a few oil slowly leaks out after it is shut off"
Please elaborate... This makes no sense.
Have you done a leak down test on the rebuilt motor?  Sounds like excessive crankcase pressure.
 but what's a good fix for too much case pressure?
Bad piston rings or cylinder are a cause.
