cylinder to piston clearance
have a B cylinder for a yz 85. probably upwards of 80 hours on it. Don't have the recommended tools to check cylinder to piston clearance. want to determine if i should go to C piston. Any recommendations to get clearances with out telescoping feeler gauges/bore gauge?
I don't think you'd have any issues using a C sized piston in a 80 hour B sized cylinder.
As an example, no matter if you have a low hour A cylinder on your bike
when you order a complete YZ125 piston kit from Yamaha, it includes a B sized piston.
On my YZ125, I put a B sized piston in my A cylinder that only had about 15 hours of use.
Just made sure I warmed the engine up gradualy before putting a load on it during break-in.
It looked fine 20 hours later when I replaced it.
Make sure you check/adjust the ring end gap. (feeler gauge required)
Edited by mlatour
perfect, thanks man
According to your other post it sounds like you had decided to try the C since you already purchased it.
https://thumpertalk.com/topic/1167668-fng-dropped-brand-new-piston/
If you choose to use that dropped piston, piston sizing won't be your main concern.
It should be ok but myself wouldn't chance it.
Edited by mlatour
The difference between an A and D YZ250 piston isn't more than .00059" (.015 mm).  Exactly the same as the 125 pistons and 3 times smaller than the tightest recommended clearance (YZ250).  Probably similar for an 85.  I believe a D piston is recommended in all used cylinders, A,B,C or D.
Edited by bg10459
As as comparison, this is from my 125's manual:
'A' = 53.957 - 53.960
'B' = 53.961 - 53.964
'C' = 53.965 - 53.968
'D' = 53.969 - 53.972
It's sometimes been said, grasp an A piston in your hand for a few minutes
and your body heat alone will make it expand almost into the B size tolerances.
Edited by mlatour
...and if you want to get specific,
an A piston might measure as a
D, ...have seen major variences
with some piston manufacturers.
If you want to be safe, take the
cyl to a shop to measure,
only takes a minute.
About as tight as you want to be
on an MX 125 is about .0016",
with a cast piston. Forged pistons
are a more dense aluminum, and
will expand more when heated,
so 0020" is about minimal.
The worst thing though, is not properly
warming up a bike. Lotsa business out
there cuz people start a cold motor, rev
it to the moon. The piston heats up and
expands instantly, the cyl doesnt. The
piston just got bigger than the cyl bore.
Either a "cold stick ", or worse, the piston
cracks in half, and destroys everything.
Never fails, everytime I go riding someone pulls up in the parking area, un-loads their 2-stroke and revs it to the moon as soon as it fires up... :bonk:
