74 Ossa Explorer
I just picked up a Ossa Explorer. It's in really good shape except someone painted it black. I want to paint it white with a blue stripe. What's the best way to strip paint off fiberglass?
Does the black paint have to all come off? Consider lightly sanding and then wiping clean with isopropyl alcohol (wear nitrile gloves). At that point, I would apply primer. Next, apply the top coat. I get decent results with a rattle can. Very cool bike by the way.
I'm in the fiberglass paint stripping process myself on some Rickman glass, I read about CitrusStrip on a boating website. I tested on a small area first. It doesn't attack the gel coat like some others I tried. Nice citrus smell too.
These parts had many layers of paint. Also worked well on another piece which had epoxy paint.
Available at Home Depot.
Before & after photos attached.
I'm curious if someone didn't paint over the original ugly brownish gold color. The black paint on the tank is all bubbled up. I will try the citrus strip and see what's under the black.
I picked up a Ossa MAR tank and extra explorer side panels for my bike. I bought them from a friend of mine that has a lot of Ossa parts. He also sells reproduction parts.
I need some kind of owners manual for my Ossa Explorer 250. I have the shop manual which is really good for rebuilds, but I would like a simple owners manual too.
I don't see anyplace to fill the transmission oil on the Explorer. Anyone know anything about changing the transmission oil on the Ossa's?
I got some citrus paint stripper and it worked great! I got most of the black paint off the original side panels and they don't look too bad there original bronze color
. ImageUploadedByThumper Talk1453427896.771213.jpgImageUploadedByThumper Talk1453427919.366712.jpg
I'm getting my Ossa Explorer set up like a Ossa MAR trials for the vintage trials that starts here this spring. I have plastic fenders to install, MAR tank (needs paint and sealing), extra side panels (white with blue stripe). I'm also replacing the 13 tooth front sprocket with a 11 tooth one to gear it down for trials. Anyone think of anything else I can do to my bike to get it ready? I'm cleaning up and restoring all the original parts that I took off (alloy fenders, Explorer bronze color tank and side panels, head light) I'm looking for a MAR seat so I can save the excellent shape Explorer seat. Also looking for a taillight and speedometer.
ImageUploadedByThumper Talk1453428941.385300.jpgImageUploadedByThumper Talk1453428977.675633.jpgImageUploadedByThumper Talk1453429005.312038.jpg
On the clutch side, there is a small cover with the OSSA leaf (I understand really a stylized shutter)- held on with two screws.
You fill there.
I have a 74 Explorer also (plus a 2014 Explorer) and 72 MAR (with. Pioneer engine)
Mine has very, very low hours- I bought it from the original owner.
You may want to do a leak down and verify the crank seals are good, or just replace them. The flywheel side especially seems to fail from age.
I changed to an OKO carb (Atlantic Trials) and it works wonderfully. The original Amal was having leaking issue and the OKO is very inexpensive, but works great.
Not a huge different between the MAR and Explorer- little things.
You can buy reproduction alluminum fenders pretty cheap also.
Mark
5190360404108723674074940dfbcc85_zpsknee
Mark, nice Explorer! It's been a long time since I replaced crank seals on a bike. I know some bikes you don't need to split the cases to replace the seals. How hard are the seals to replace on the 74 Explorer?
What transmission oil are you using in your Explorer? Thanks, Ash
Seals are pretty easy.
The flywheel side, pull flywheel and Motoplat (mark it first)
Hook the old seal out, find a suitable driver to push the new one in.
Clutch side can be a bit more effort.
(Depending on the Cush drive)
But no splitting cases.
Both of the older OSSAs I have right now had bad seals. I sourced them form a bearing supply house- but the usual OSSA suppliers carry them also.
Symptoms I saw.
Hard to start (especially cold- OSSAs usually are VERY Easy starters)
High, hanging idle.
Mark, thanks for the info. Mine didn't start easy but the carb is dirty. It didn't seem to idle high though. I'll order the seals and have them on hand. I have both tanks off getting ready to seal both then paint. I haven't got into the carb yet but I have read that the OKO carbs were a great improvement over the old stock carb.
I've sealed sevaral tanks.
The most important part is prep.
Clean it as well as you possibly can.
Then clean it again.
Rattle some drill screw around until your arm falls off.
Let it dry REALLY well.
Make sure to mix the sealer well.
I'm going to use the Caswell tank sealer. The kit I have should be enough to do both tanks.
Tank looking good.
I'm going to repaint mine this spring/summer.
I'll get back to you in trans oil. Kieth Lynas had a recommended one that I use.
Mark
