1996 xr250 wont start after valve cover removal
I have a 1996 xr250 and it would only crank if roll started and I took the valve cover off and put it back on torqued bolts in cris cross pattern and now won't even roll start any ideas would be greatly appreciated
Do  you mean the engine won't turn over when using the kickstarter? If so, it sounds like something is wrong with the kickstarter. When you say you torqued the bolts in a criss cross pattern, aren't you describing the cylinder head, not the valve cover? Did you install the camshaft correctly?
Edited by Brian1980
There's a plunger and spring under the chain side of the cam. If you removed the cam and wasn't aware of those parts and they came out and got lost, the bike will not start without them being installed.
