Pesk crank bearing retaining torx screws
I use a heatgun to loosen the loctite then a torx bit on a ratchet. Never had a problem getting them out that way.
Hey if you remember.. Im up to installing clutch n kickstart stuff.. All looks good.. Just one question.. Idk if u can remember.. The kickstart gear n the idler gear.. When the gears mesh. It seems there not totally meshed even.. Hard to explain.. But where they mesh one gear is in the middle of the other gear.. Not totally even.. Maybe cause case is laying on its side.. Ive double checked install.. Using
Manual. And all correct. You got any input..
