Lifan 124cm3 pit bike motor blowing oil?
does anybody know why my lifan 124cm3 motor keeps blowing oil out of the crankcase breather hose constantly while riding?
Oil is blown out by excessive pressure build-up in the crankcase.
meaning combustion pressure is making it's way past the piston & rings.
Is there also a possibility the oil was overfilled?
is there any way to fix? the oil level is fine
another simple check would be to confirm the vent hose doesn't have any restrictions,
meaning pressure gradualy builds-up until high enough to overcome the restriction and then blow out,
once the pressure is released the restriction (say a pinched hose / connector etc.) would close up again.
Also, if you had the engine's specs would could run a compression test to confirm yours is within spec.
or better yet a leakdown test would show how much loss there is (for you to search what is the acceptable %)
Edited by mlatour
