2011 Crf250r Clutch lifter issue
So i am doing a top end rebuild and a few crank case seal and gaskets so i pulled my clutch lifter lever out and replaced the seal and when i went to re install it wouldn't go completely back down so i took it back out to take a look and i fount something interesting there was some kind of dowel in the bottom of it so i worked it up and out not to sure what it goes to any help would be great. it isn't in any of the diagrams in the service manual so not quite sure where it came from. I attached some pictures for help.
that's what is left of a caged needle bearing that supports the shaft
there are actually 2 bearings in there.kind of hard to tell from pic of your shaft which bearing came apart.hopefully for you its the top bearing!look closely at the shaft you may see some galling on it.pull your seal and look inside w/light,hopefully where the bearing was seated the aluminum isn't messed-up
