Engine swingarm mount
Can anybody give me the measurement for the distance between swingarm spacers on the back of the klr600 ?. I need from outside of one spacer to the outside of the other please ( on the engine )
Thanks
micky0121
Thanks
micky0121
You are looking for the width of the swing arm space? I thought it was the same as the 650?
I make it 8-1/8" across the spacer tubes. If needs to be more accurate than that, I'll need more time to check. How accurate does it need to be?
Hi Normk
Sorry that is not the measurement I want . the measurement I require is on the engine , the outside measurement where the swingarm mounts . from one side of the hardened bearing to the side of the other outside side hardened bearing .
I am mounting a 650 swingarm to a 600 and there is a difference on the mount .
Thanks micky0121
