Kx250 fouling plugs every ride
So sick of putting a new plug in every time I ride.
Plug is fine all morning until I stop to have some food and then go to start the bike again and runs for 30seconds and then fouls the plug. Tried playing around with mixtures, defiantly riding the bike hard enough any ideas??
If you lug around in the bush, even if you lug hard your sparkplug prbably ain't hot enough. Most 2 stroke mx bikes run pretty cold plugs stock cuz they're designed to be ridden on the pipe literally all the time. Haven't been on bikes all that long so I can't say much else
I was just about to say clutch side crank seal, but I got beat. I'd definitely make sure that was new if you're doubting it.
Yer the seal was the first thing I checked out and it's fine was only put in about 1hrs worth of riding ago. The next thing on the list was to pull the carby down and check the jetting. Still a new bike to me and previous owner has no idea about it.
So I guess I hit the jetting next!
My sons 2002 KX250 did the same thing to him when he first stated riding it. We went to Super M oil, changed the ratio from 32:1 to 40:1 and adjusted the air/ fuel mixture a little. Hasn't fouled in over a year now. Didn't change jetting because the bike had been ridden at about the same temp and altitude prior. The only change we make on it now is air/fuel mix based on air temp.
?  Reference to "checking crank seal"  How, pray-tell do you "check" it?!
You don't....you replace it.
Does the bike visibly smoke when riding after its warmed up?
I have not fouled a plug in at least ten years.  Never in my 250.  If the jetting is close and there's nothing wrong with the motor it should not happen.
If the crank seal is bad it'll be smoking like a chimney.  That's how you check.
Yer it isn't smoking like a chimney and the brand new seal.
That's why I'm thinking the might be something wrong with the jetting because I've never fouled plugs before until I got the kx
Edited by kx250dan
What jets are you running currently?  Depending on your elevation you might try a 45-48 pilot.  These things come rich stock, even for sea level.
Pressure test. If the crankcase holds pressure the seal is holding. I'd still perform this test because it isn't the first time a seal has been damaged on installation.
I'm not to sure as its a new bike with the previous owner knowing nothing so hopefully pull it down and have a look to see what it's running
Really??
Leak down test, cork off carb manifold, cork of exaust spigot, pressureize with correct amount of air in the cylinder, remove unnecessary mechincal parts obscuring view of said seals, spray all junctions with soapy water, and if air bubbles are forming, theres your leak!
Specifics on pressure testing a two stroke here
https://thumpertalk.com/topic/432226-pressure-testing-a-2-stroke/
Haha thanks. I know. That was just my lame attempt at sarcasm. Sometimes I wonder why people post their obtuse "advice" in such an obnoxious way when they obviously don't really know what they're talking about. They could at least be nice about it, then they wouldn't look foolish.
I'm actually in the middle of that project right now on my KX100, but can't figure out how to plug the case vent next to the PV. Any ideas? I'll ask on my other thread. Sorry to OP for thread hijack.
Edited by Bron-Yr-Aur
