Technology Elevated Co smart carb
https://technologyelevatedco.com
Just ran into an advertisement for this company and wanted to see if you guys knew about this?
Info copied from their site:
Single Circuit Flat-Slide Design
No Jets
No Accelerator Pump
Easy External Adjustments
Proprietary High Velocity Venturi
Excellent Throttle Response
Linear Throttling
Precision Flat Ground Metering Rod
Ultra-fine Fuel Atomization (+10-14% HP)
Unparalleled Fuel Economy (+30%)
Float Bowl Pressurization Circuit
Ambient Air Density Compensation
Passive Auto Altitude Mixture Correction
Internally Vented & Sealed From Atmosphere (no fuel spillage)
Lowest Evaporative Emissions Ever Tested
Similar basic design to the Edelbrock and Lectron. Lectrons were always great , the Edelbrock not so much. There's a bit more to tuning one than just turning the knob for the needle and there ARE different needles. With the Ede's a lot of guys could never get top end and bottom adjusted well at the same time , but they may have just needed other needles to try. Internally vented means it spills and/or overflows into your motor.
Edited by JoeRC51
the SC soiled it's rep with innumerable deposits before product being ready, multitude of tech issues, etc. They aren't cheap and the benefits are questionable. If this design is of interest, go Lectron.
  • Like 2
Okay, didn't realize it was the same Smart Carb I had seen referenced before. I must have never had a look at it, as far as interest I am still sold on my Mikuni tmx.
