05-07 CR250 wear points to keep an eye on
2D99564F-583B-48A9-A5B1-C56C9A622E8E_zps
Left side radiator will wear from contact with the ignition wire bundle.  05 CR250 with 227 hours total time.  Keep an eye on yours before a leak begins.
08dca857-06d5-4e77-bfb9-c6e5303348c8_zps
The subframe will wear on the upper surface of the lower struts where contact with the airbox occurs.
05584B28-1293-4264-A761-B8D8FB78CFDE_zps
Mine wore a hole completely through.
9224260A-F42B-457A-8BDC-28C78A6A2A89_zps
Most guys are already familiar with the frame wear issue from contact with the radiator shrouds.  Just add heavy tape (removed for photo) and lightly relieve the contacting point on the radiator shroud and you are good to go.
  • Like 2
