2014 KXF450 PSF Pressure Loss
Hi Guys. Looking for a bit of help. I've got a 2014 KXF 450 PSF Forks up front. I was also running a Split Stream Uni Valve, and have recently noticed that the forks were losing all of their pressure down to 0psi
Initially, I thought it was a problem with the Uni Valve system causing a leakage and probably through my handiwork of fitting. So, I removed the Uni Valve System and noticed that there was still a loss of pressure but only from one fork leg. The loss of pressure was pretty quick, I would say over a period of around 10mins maybe longer.
Does this sound like a fork seal gone or something else?
Any help and advice is greatly appreciated
That's why I never liked that split stream unit, if one leaks they are both going down. Probably fork seal, but you could air it up and spray some soapy water around on the seal and around the cap and see if you get bubbles.
