Adjusting the Pilot Screw on DR350 / BST33 carb
Which tool/technique do you use for adjusting the pilot screw whilst the engine is running?
There is insufficient clearance under the carb for even an angled screwdriver.
Thanks.
I had to loosen the two clamps on carb and rotate carb enough to make an adjustment. Then rotate back and tighten clamps. Start it up to check improvement. Time consuming but will work.
