Cr80 build
Just got 1995 cr 80small wheel ...an a 2003 cr85rb with bad motor. Could they fit they together,......thanks ride safe yall
Possibly but the mounts won't be the same and I'm not sure about the rear mount the swingarm bolt passes thru. It may work if you can do some fabricating
I've got the engine bolted down.. But the exausght doesn't connect to the head properly. I'm wondering will the big wheel swingarm go on the small frame
2003cr85rb swingarm will not fit to 96 frame. The motor from the 96engine will go on the 03 but the pipe doesn't mount to flange an the swingarm/engine bolt is about 1/2 inch short. I'm want to big wheels so me an a buddy can trail ride. Anybody selling a motor for a 03.
they'll fit perfectly the bottom end is the same you'll need a new pipe due to flange but other than that perfect.
Gas Tanks
1996 - 2002 white
2003 - 2007 black
(tanks have different mounting points on the frame, can be "engineered" to fit.
Frame
1996 - 2002 (2002 went to silver paint)
2003 - 2004 (CR85 tank mounts is the only change)
2005 - 2007 (reocated coil location and rear brake reservoir location)
Engine
1996 - 2007 Bottom end same
1996 - 2002 82cc, male exhaust flange
2003 - 2004 85cc, male exhaust flange
2005 - 2007 85cc, female exhaust flange
Exhaust
1996 - 2004 fits male exhaust flange
2005 - 2007 fits female exhaust flange
Silencer
1996 - 2007 all interchange
Carbs
1996 - 2004 Keihin round slide carb
2005 - 2007 Keihin flat slide carb
Forks
Rear Shock
Seat
Rims
CR80R/CR85R - 17" front and 14" rear
CR80RB/CR85RB - 19" front and 16" rear
Fenders (front and rear), fork guards, front number plate
1996-2002 CR80R and CR80RB
2003-2007 CR85R and CR85RB
CRF150R front fender fits and looks much better
all interchange
Radiator Shrouds
1996-2002 CR80R and CR80RB same
2003-2007 CR85R and CR85RB same
CR80 and CR85 will not interchange due to tank redesign
Side number plate
Will physically interchange (slight visual difference, CR80 had flat rear end, CR85 had pointed rear end)
this is not my post its jump6packs
