Dirtbike/pitbike leaking oil
Hello guys I have an apollo dirtbike 125cc and its leaking oil like 1 drop every 5 seconds but it only leaks when I stop using it... What can I do? can I use oil stop leak on it?
That video really doesn't show exactly where the oil is leaking.
If I knew where it is leaking from I would not post this I don't think I put too much because one time I thought the same thing so I let it leak out thinking I put too much then I was riding it and the piston got stuck so I had to unstick it and fix it again so tbh I don't think I put too much
I think you need to pull the motor from the bike. My guess is if it's running ok, you either have a crack in the case somewhere, or the drain plug cross threaded and oil is slowly leaking from there.
