Crf 450 08 engine oil getting higher
Does it smell like gas?  Anti-freeze?
The obvious answer is something is leaking in ....is the trans side lower?
Sounds like you have oil migration. Your right crankcase seal or your counter balance shaft seal is bad. Pretty common deal, and easy to change. Search oil migration in here and there is about a million different threads on it. Some of them give good Info on what you need to do.
