2016 YZ250f stick shim stacks
Hi guys,
does anyone have the stock fork and shock shim stacks for a 2016 YZ250F?
Thanks
If nobody chimes in, I'll have them Tuesday when I revalve mine.
Shock
Rebound
40.20x5
25.11
40.30
38.30
36.30
34.30
32.30
30.25x2
28.25x2
26.30
Compression
44.20x12
37.15
42.20
40.20
38.20
36.20
34.20
32.20
30.20
28.20
27.20
26.20
25.30
Awesome, Ty!
Does anyone have the fork stacks?
Edited by mxboy55
It amazes me when I see that rebound stack ,the doubled up 0.25 at the end of the stack are almost identical to single 0.3 so why bother ? Any shim that close to the clamp isn't going to be felt unless you make huge changes eg going from a single 0.20 to maybe 2*0.3s
Going by memory here so i might be off a little. It should be pretty close.
Fork base
32.11x22
28.11
26.11
24.11
23.11
22.11
21.11
20.11
19.11
18.11
17.20
MVc
20.11x4
17.11x2
10.20x2
13.30
15.30
17.30
MVr
20.11x3
12.11
20.11
18.11
16.11
14.20
13.20
12.20
11.20
I agree mog, I replaced the double .25s with .30s for simplicity and set up a 3 stage stack for reb and comp. Forks I pulled a couple bv face shims, built a 2 stage mv and a better rebound stack. Bike is phenomenal now!
Not trying to hijack the thread, but would the valving in a newer machine such as the OP's make for better suspension in an older bike? Let say I changed my valve stacks in my 2006 yz250f to match the OP's 2016.
You could do it with the forks but they can be improved greatly over the stock 16. Stock was harsh and made the front tire want to push in corners.
The 06 put less weight on the front wheel ,so requires a softer stack than a 16 ,basically it won't work the same as on a 16
